This command disables the overload-bit feature.
| area_name | Specifies the area name of the IS-IS process for which this feature is to be disabled. |
Disabled.
Disabling the overload bit feature causes an SPF recalculation throughout the network. In addition, external and interlevel router redistribution is no longer suppressed if those options were included when the overload bit was enabled. If the overload bit is currently set as a result of the overload-bit on-startup command, this command overrides the configuration and disables this feature.
The following command disables the overload bit feature for areax:
disable isis area areax overload-bit
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
